Schemas Budgie #11
Closed
opened 2016-01-24 17:32:40 +00:00 by philm · 23 comments
philm commented 2016-01-24 17:32:40 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Hi there..
schermata del 2016-01-24 18-31-37
Budgie not have schema ??
*Created by: Ste74* Hi there.. ![schermata del 2016-01-24 18-31-37](https://cloud.githubusercontent.com/assets/11218234/12537798/bcd8422e-c2c8-11e5-90e0-34ff9529e760.png) Budgie not have schema ??
philm commented 2016-01-24 19:02:45 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: ringo32
mayby is like 👍
[org.solus-project.budgie-panel.applets.{WEIRD-code}]
alignment='start'
name='Icon Task List'
position='2'
but its possible has no Dconf for that, go to /usr/share/budgie-panel if there exist, look if there eventual a layout file exist... if so, then must in dconf-editor a menu exist which layout it needed...
just use dconf and experiment bit by bit the gschema's...
in this case its not org :)
you can find the id's :
https://github.com/solus-project/budgie-desktop/blob/master/data/com.solus-project.budgie-panel.gschema.xml
think above comes close as example but not exact..
what is changed should be
Name='Value'
further above like
[com.solus-project.budgie-panel.panel]
thats the schema_id ,
i suppose enum_id comes under is you see on the link ?
*Created by: ringo32* mayby is like :+1: [org.solus-project.budgie-panel.applets.{WEIRD-code}] alignment='start' name='Icon Task List' position='2' but its possible has no Dconf for that, go to /usr/share/budgie-panel if there exist, look if there eventual a layout file exist... if so, then must in dconf-editor a menu exist which layout it needed... just use dconf and experiment bit by bit the gschema's... in this case its not org :) you can find the id's : https://github.com/solus-project/budgie-desktop/blob/master/data/com.solus-project.budgie-panel.gschema.xml think above comes close as example but not exact.. what is changed should be Name='Value' further above like [com.solus-project.budgie-panel.panel] thats the schema_id , i suppose enum_id comes under is you see on the link ?
philm commented 2016-01-24 19:55:50 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
Hi Ste,
I think you know more about Budgie than I do.
I have no idea if budgie uses glib schema.
*Created by: udeved* Hi Ste, I think you know more about Budgie than I do. I have no idea if budgie uses glib schema.
philm commented 2016-01-24 20:20:22 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
No i have just search a file .conf or .ini for budgie but not provide this version .. so search the key in repo solus on github
*Created by: Ste74* No i have just search a file .conf or .ini for budgie but not provide this version .. so search the key in repo solus on github
philm commented 2016-01-24 20:50:46 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: ikeydoherty
The default layout is baked in with the panel.ini file:
https://github.com/solus-project/budgie-desktop/blob/master/data/panel.ini
This will create the default panel layout and applet instances upon first run.
If you need support for a vendor file to overwrite this, I can easily add this.
We use relocatable schemas to give each applet and panel unique instance data within dconf, where "{WEIRD-code}" is actually a UUID. These should not be manually butchered.
Each applet that exposes a configuration of some sort does so via it's own gsettings, as an example:
https://github.com/solus-project/budgie-desktop/blob/master/panel/applets/icon-tasklist/com.solus-project.icon-tasklist.gschema.xml
The Solus LiveCD overrides this by example, in /usr/share/glib-2.0/schemas/com.solus-project.icon-tasklist.gschema.override:
[com.solus-project.icon-tasklist]
pinned-launchers=['os-installer.desktop']
*Created by: ikeydoherty* The default layout is baked in with the `panel.ini` file: https://github.com/solus-project/budgie-desktop/blob/master/data/panel.ini This will create the default panel layout and applet instances upon first run. If you need support for a _vendor file_ to overwrite this, I can easily add this. We use relocatable schemas to give each applet and panel unique instance data within dconf, where "{WEIRD-code}" is actually a UUID. These should **not** be manually butchered. Each applet that exposes a configuration of some sort does so via it's own gsettings, as an example: https://github.com/solus-project/budgie-desktop/blob/master/panel/applets/icon-tasklist/com.solus-project.icon-tasklist.gschema.xml The Solus LiveCD overrides this by example, in `/usr/share/glib-2.0/schemas/com.solus-project.icon-tasklist.gschema.override`: ``` ini [com.solus-project.icon-tasklist] pinned-launchers=['os-installer.desktop'] ```
philm commented 2016-01-24 20:55:00 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Thank you friend for explain .. ;)
*Created by: Ste74* Thank you friend for explain .. ;)
philm commented 2016-01-24 20:55:54 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
Can I close Stefano?
*Created by: udeved* Can I close Stefano?
philm commented 2016-01-24 20:58:36 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Yes , i close by itself ;)
*Created by: Ste74* Yes , i close by itself ;)
philm commented 2016-01-24 21:00:14 +00:00 (Migrated from gitlab2.manjaro.org)
Please open a Budgie issue if you'd like support for a vendor file :)
*Created by: ikeydoherty* Please open a Budgie issue if you'd like support for a vendor file :)
philm commented 2016-01-24 21:01:32 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
I think we can do vendor files with schema-override files?
*Created by: udeved* I think we can do vendor files with schema-override files?
philm commented 2016-01-24 21:03:15 +00:00 (Migrated from gitlab2.manjaro.org)
@udeved not for the panel.ini you can't :)
*Created by: ikeydoherty* @udeved not for the `panel.ini` you can't :)
philm commented 2016-01-24 21:03:57 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
You only need a file that you can overwrite or not?
*Created by: Ste74* You only need a file that you can overwrite or not?
philm commented 2016-01-24 21:04:39 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
The question is, do you need a customized panel.ini Ste?
*Created by: udeved* The question is, do you need a customized panel.ini Ste?
philm commented 2016-01-24 21:05:09 +00:00 (Migrated from gitlab2.manjaro.org)
^ Dude asks good questions :p
*Created by: ikeydoherty* ^ Dude asks good questions :p
philm commented 2016-01-24 21:05:57 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
Dude is 20 years in business. :)
*Created by: udeved* Dude is 20 years in business. :)
philm commented 2016-01-24 21:06:54 +00:00 (Migrated from gitlab2.manjaro.org)
Fair play, dude. :p
*Created by: ikeydoherty* Fair play, dude. :p
philm commented 2016-01-24 21:07:10 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Depend .. If you see Rc1 is "vanilla" panel . If you see the picture at the first i have modified .. Moved app , add app .. changed the theme
*Created by: Ste74* Depend .. If you see Rc1 is "vanilla" panel . If you see the picture at the first i have modified .. Moved app , add app .. changed the theme
philm commented 2016-01-24 21:07:51 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
The panel items are also defined in panel.ini?
Or is this part in dconf?
*Created by: udeved* The panel items are also defined in panel.ini? Or is this part in dconf?
philm commented 2016-01-24 21:08:06 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
i'm arbiter :)
*Created by: Ste74* i'm arbiter :)
philm commented 2016-01-24 21:09:34 +00:00 (Migrated from gitlab2.manjaro.org)
So panel.ini is literally only for the first panel(s) layout, nothing more. If you want to override each applet config, well, that's actually down to the gsettings schema files
*Created by: ikeydoherty* So `panel.ini` is literally only for the first panel(s) layout, nothing more. If you want to override each applet config, well, that's actually down to the gsettings schema files
philm commented 2016-01-24 21:10:47 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
Yes, initialize panel with ini file, I thought so.
I think you can do rest in gsettings Ste, and use default layout?
*Created by: udeved* Yes, initialize panel with ini file, I thought so. I think you can do rest in gsettings Ste, and use default layout?
philm commented 2016-01-24 21:14:18 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Ok .. i leave the default layout
*Created by: Ste74* Ok .. i leave the default layout
bittin commented 2022-08-11 07:24:25 +00:00 (Migrated from gitlab2.manjaro.org)
mentioned in merge request !261
Chrysostomus commented 2022-08-11 10:28:50 +00:00 (Migrated from gitlab2.manjaro.org)
mentioned in commit e10700a38d
mentioned in commit e10700a38db548b66e2898547564730ff6156246
Sign in to join this conversation.
No milestone
No project
No assignees
1 participant
Notifications
Due date
The due date is invalid or out of range. Please use the format "yyyy-mm-dd".
No due date set.
Dependencies
No dependencies set.
Reference
profiles/desktop-settings#11
No description provided.
