xinitrc is not working for multiple environments #124
Closed
opened 2018-05-26 14:05:49 +00:00 by philm · 8 comments
philm commented 2018-05-26 14:05:49 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Chrysostomus
The current version of xinitrc that uses the get_session function is meant to allow easily switching between desktop environments from tty. It does not do what it is supposed to. This one works:
https://github.com/manjaro/desktop-settings/blob/master/community/bspwm/skel/.xinitrc
It does not interfere with displaymanagers or autologin, and if you run startx <name_of_environment it starts the desired environment as it is supposed to.
If anyone doesn't have anything against it, I'll be fixing it for different editions.
@oberon2007 @philmmanjaro @Ste74
*Created by: Chrysostomus* The current version of xinitrc that uses the get_session function is meant to allow easily switching between desktop environments from tty. It does not do what it is supposed to. This one works: https://github.com/manjaro/desktop-settings/blob/master/community/bspwm/skel/.xinitrc It does not interfere with displaymanagers or autologin, and if you run `startx <name_of_environment` it starts the desired environment as it is supposed to. If anyone doesn't have anything against it, I'll be fixing it for different editions. @oberon2007 @philmmanjaro @Ste74
PRESFIL commented 2020-07-19 08:44:42 +00:00 (Migrated from gitlab2.manjaro.org)
I have the same problem under manjaro-i3-community. Maybe you are an old ticket, or you missed it (because you changed the repository structure), but this is old problem.
I think we should do as it says here:
  • add $1 ($1 inside function evaluates to function's parameters - not to script's parameters. Here $1 parameter need to be passed explicitly)
  • replace the interpreter with bash (POSIX sh does not supports += operator, as shellcheck tells)
The following patch works for me:
diff --git a/community/i3/skel/.xinitrc b/community/i3/skel/.xinitrc
index 1c510bc..5aa8c64 100644
--- a/community/i3/skel/.xinitrc
+++ b/community/i3/skel/.xinitrc
@@ -1,4 +1,4 @@
-#!/bin/sh
+#!/bin/bash
 # ~/.xinitrc
@@ -63,4 +63,4 @@ get_session(){
        echo "dbus-launch ${dbus_args[*]}"
-exec $(get_session)
+exec $(get_session "$1")
but these fixes need to be applied to all **/.xintirc files (or write a single one), not just for manjaro-xfce (as far as i understand, they are not needed when running through desktop-manager).
I have the same problem under **manjaro-i3-community**. Maybe you are an old ticket, or you missed it (because you changed the repository structure), but this is [old](https://forum.manjaro.org/t/stable-something-wrong-with-default-xinitrc/37595/4) problem. I think we should do as it says [here](https://forum.manjaro.org/t/stable-something-wrong-with-default-xinitrc/37595/4): - add `$1` (`$1` inside function evaluates to function's parameters - not to script's parameters. Here `$1` parameter need to be passed explicitly) - replace the interpreter with bash (**POSIX sh** does not supports `+=` operator, as `shellcheck` tells) The following patch works for me: ```diff diff --git a/community/i3/skel/.xinitrc b/community/i3/skel/.xinitrc index 1c510bc..5aa8c64 100644 --- a/community/i3/skel/.xinitrc +++ b/community/i3/skel/.xinitrc @@ -1,4 +1,4 @@ -#!/bin/sh +#!/bin/bash # # ~/.xinitrc # @@ -63,4 +63,4 @@ get_session(){ echo "dbus-launch ${dbus_args[*]}" } -exec $(get_session) +exec $(get_session "$1") ``` but these fixes need to be applied to **all** `**/.xintirc` files (or write a single one), not just for **manjaro-xfce** (as far as i understand, they are not needed when running through desktop-manager).
oberon commented 2020-08-04 09:38:14 +00:00 (Migrated from gitlab2.manjaro.org)
yes. we never adjusted that in all the different places... Fixing that now finally.
oberon commented 2020-08-04 09:38:55 +00:00 (Migrated from gitlab2.manjaro.org)
mentioned in commit manjaro-kde-settings@e6e6af5cff6f659631b14b15ceee8588c24708fc
oberon commented 2020-08-04 09:47:33 +00:00 (Migrated from gitlab2.manjaro.org)
mentioned in commit manjaro-xfce-settings@20c236b14645fbf3d969bcc484e94869e01daf88
oberon commented 2020-08-04 09:56:54 +00:00 (Migrated from gitlab2.manjaro.org)
mentioned in commit manjaro-gnome-settings@256c4af6b55e208d443a247e4810c9783fb1b31d
oberon commented 2020-08-04 10:21:24 +00:00 (Migrated from gitlab2.manjaro.org)
mentioned in commit 7c6322e094
mentioned in commit 7c6322e0944c68aebfed6f8af3a138bd6f2e8c2c
oberon commented 2020-08-04 10:51:02 +00:00 (Migrated from gitlab2.manjaro.org)
closed
closed
changed the description
Sign in to join this conversation.
No milestone
No project
No assignees
1 participant
Notifications
Due date
The due date is invalid or out of range. Please use the format "yyyy-mm-dd".
No due date set.
Dependencies
No dependencies set.
Reference
profiles/desktop-settings#124
No description provided.
