schema override #9
Labels
No labels
bug
duplicate
enhancement
help wanted
invalid
question
wontfix
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
Dependencies
No dependencies set.
Reference
profiles/desktop-settings#9
Loading…
Add table
Add a link
Reference in a new issue
No description provided.
Delete branch "%!s()"
Deleting a branch is permanent. Although the deleted branch may continue to exist for a short time before it actually gets removed, it CANNOT be undone in most cases. Continue?
Created by: udeved
Is there an order for sections and keys to keep?
Does somebody know?
I don't get mate or gnome to talk in sonar, but accessibility is nicely activated as separate menu.
I think the order doesn't matter.
Created by: udeved
Hmm, perhaps we got to play around with the weighting of the override, even though its already highest with 99.
Some sonar settings don't get activated by default.
Created by: ringo32
mayby is 99 To high :) if you plan a livecd gschema like to make lock screen work at first hand... lockely in livecd lockscreen works... so it stil enabled to go intoo lock..
99 get to high on number, likely a gschema for a livesession need a higher number to disable lockscreen as example
