cleanup oem-profiles containing #192
Labels
No labels
bug
duplicate
enhancement
help wanted
invalid
question
wontfix
No milestone
No project
No assignees
1 participant
Notifications
Due date
No due date set.
Dependencies
No dependencies set.
Reference
profiles/iso-profiles#192
Loading…
Add table
Add a link
Reference in a new issue
No description provided.
Delete branch "%!s()"
Deleting a branch is permanent. Although the deleted branch may continue to exist for a short time before it actually gets removed, it CANNOT be undone in most cases. Continue?
As described in this issue - there may be issues with old systems.
https://forum.manjaro.org/t/184652
The current KDE Plasma profiles does contain
/etc/sddm.confso it is likely a dusty remnant.I checked the profiles and removed the override
/etc/sddm.confas all of them contained the above setting, which differs from upstream where it is explicitly setassigned to @philm and @fhdk
mentioned in merge request !389
changed the description
@fhdk this broke autologin on Plasma ISOs. Just tested with OEM ISO for Starlabs
How can you build an OEM ISO - when the calamares oem settings is missing from repos?
