Thunderbird shows wrong release banner #3
Closed
opened 2020-06-29 03:37:19 +00:00 by kisb · 3 comments
kisb commented 2020-06-29 03:37:19 +00:00 (Migrated from gitlab2.manjaro.org)
When I open Thunderbird, it shows the Daily banner instead of the Stable release one. That's because the URL being used is https://live.thunderbird.net/thunderbird/start?channel=release-cck-archlinux. (There are other queries in the URL but they're unrelated to the issue. You can check the full URL in Preferences.) The workaround is changing channel to just release, but other queries won't change any more (like version).
The line app.partner.archlinux=archlinux the distribution.ini file for Thunderbird in this package causes the URL to include release-cck-archlinux instead of release. If you remove this line, the whole issue is fixed. I noticed Arch Linux doesn't have this line, so I don't think removing it from the file will have any side effects.
When I open Thunderbird, it shows the Daily banner instead of the Stable release one. That's because the URL being used is `https://live.thunderbird.net/thunderbird/start?channel=release-cck-archlinux`. (There are other queries in the URL but they're unrelated to the issue. You can check the full URL in Preferences.) The workaround is changing `channel` to just `release`, but other queries won't change any more (like `version`). The line `app.partner.archlinux=archlinux` the distribution.ini file for Thunderbird in this package causes the URL to include `release-cck-archlinux` instead of `release`. If you remove this line, the whole issue is fixed. I noticed Arch Linux doesn't have this line, so I don't think removing it from the file will have any side effects.
ste74 commented 2020-06-29 17:08:51 +00:00 (Migrated from gitlab2.manjaro.org)
@kisb can you post some screenshot to understand the difference? I m not in confidence with Thunderbird settings..
ste74 commented 2020-06-29 20:35:49 +00:00 (Migrated from gitlab2.manjaro.org)
Forgot it, i removed the key
8d7740509b
Forgot it, i removed the key 8d7740509bc5e39bcab7cd3285dca675e1575e99
ste74 commented 2020-06-29 20:35:52 +00:00 (Migrated from gitlab2.manjaro.org)
closed
closed
Sign in to join this conversation.
No milestone
No project
No assignees
1 participant
Notifications
Due date
The due date is invalid or out of range. Please use the format "yyyy-mm-dd".
No due date set.
Dependencies
No dependencies set.
Reference
profiles/manjaro-browser-settings#3
No description provided.
