Qt5ct > config app #1
Closed
opened 2017-03-20 20:27:50 +00:00 by philm · 7 comments
philm commented 2017-03-20 20:27:50 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Hi guys , in order to solve this issue for mate i have also checked for gnome and budgie . I know the tread where we have adopt the solution to export the qt5 override into the .profile file and the qt5 app work fine but in this three DE if not set also the override into /etc/environment the app to config the qt5 style not work .. so why not use also this entry ? what is the reason ?
@philmmanjaro , @Kirek , @udeved
*Created by: Ste74* Hi guys , in order to solve this [issue](https://forum.manjaro.org/t/unstable-mate-1-18-in-repo-and-on-iso/19836/28) for mate i have also checked for gnome and budgie . I know the tread where we have adopt the solution to export the qt5 override into the .profile file and the qt5 app work fine but in this three DE if not set also the override into /etc/environment the app to config the qt5 style not work .. so why not use also this entry ? [what is the reason ?](https://github.com/manjaro/release-plan/issues/73#issuecomment-231221460) @philmmanjaro , @Kirek , @udeved
philm commented 2017-03-20 20:58:46 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
Can you please post from a running mate session
printenv
*Created by: udeved* Can you please post from a running mate session printenv
philm commented 2017-03-20 21:09:58 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Here is
[stemate@ste74 ~]$ printenv
LANG=it_IT.UTF-8
MANAGERPID=904
DISPLAY=:1
INVOCATION_ID=2d657e78[stemate@ste74 ~]$ printenv
LANG=it_IT.UTF-8
MANAGERPID=904
DISPLAY=:1
INVOCATION_ID=2d657e78dba84aa3a577c1a6912f5df4
GTK_OVERLAY_SCROLLING=0
COLORTERM=truecolor
SSH_AUTH_SOCK=/run/user/1001/keyring/ssh
USER=stemate
PWD=/home/stemate
HOME=/home/stemate
JOURNAL_STREAM=8:18743
MATE_DESKTOP_SESSION_ID=this-is-deprecated
DBUS_STARTER_ADDRESS=unix:path=/run/user/1001/bus,guid=8bbbc5bd9017d4dfe31e923058d043c4
MAIL=/var/spool/mail/stemate
SHELL=/bin/bash
VTE_VERSION=4601
TERM=xterm-256color
DBUS_STARTER_BUS_TYPE=session
SHLVL=1
WINDOWID=54525958
LOGNAME=stemate
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1001/bus,guid=8bbbc5bd9017d4dfe31e923058d043c4
XDG_RUNTIME_DIR=/run/user/1001
XAUTHORITY=/run/user/1001/gdm/Xauthority
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
SYSTEMD_NSS_BYPASS_BUS=1
SESSION_MANAGER=local/ste74:@/tmp/.ICE-unix/927,unix/ste74:/tmp/.ICE-unix/927
_=/usr/bin/printenv
[stemate@ste74 ~]$
*Created by: Ste74* Here is ``` [stemate@ste74 ~]$ printenv LANG=it_IT.UTF-8 MANAGERPID=904 DISPLAY=:1 INVOCATION_ID=2d657e78[stemate@ste74 ~]$ printenv LANG=it_IT.UTF-8 MANAGERPID=904 DISPLAY=:1 INVOCATION_ID=2d657e78dba84aa3a577c1a6912f5df4 GTK_OVERLAY_SCROLLING=0 COLORTERM=truecolor SSH_AUTH_SOCK=/run/user/1001/keyring/ssh USER=stemate PWD=/home/stemate HOME=/home/stemate JOURNAL_STREAM=8:18743 MATE_DESKTOP_SESSION_ID=this-is-deprecated DBUS_STARTER_ADDRESS=unix:path=/run/user/1001/bus,guid=8bbbc5bd9017d4dfe31e923058d043c4 MAIL=/var/spool/mail/stemate SHELL=/bin/bash VTE_VERSION=4601 TERM=xterm-256color DBUS_STARTER_BUS_TYPE=session SHLVL=1 WINDOWID=54525958 LOGNAME=stemate DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1001/bus,guid=8bbbc5bd9017d4dfe31e923058d043c4 XDG_RUNTIME_DIR=/run/user/1001 XAUTHORITY=/run/user/1001/gdm/Xauthority PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin SYSTEMD_NSS_BYPASS_BUS=1 SESSION_MANAGER=local/ste74:@/tmp/.ICE-unix/927,unix/ste74:/tmp/.ICE-unix/927 _=/usr/bin/printenv [stemate@ste74 ~]$ ```
philm commented 2017-03-20 22:10:14 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
Do you try to export $QT_QPA_PLATFORMTHEME in this mate session?
And if, in what file?
*Created by: udeved* Do you try to export `$QT_QPA_PLATFORMTHEME `in this mate session? And if, in what file?
philm commented 2017-03-21 18:05:36 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Sorry for delay :) ,yesterday after play with gdm to do a theme for manjaro i have break my system :D ..
After manage in console i come back again :p .. so to answer at your questioni have exported the override in the .profile file in according with manjaro-base-skel right ?
*Created by: Ste74* Sorry for delay :) ,yesterday after play with gdm to do a theme for manjaro i have break my system :D .. After manage in console i come back again :p .. so to answer at your questioni have exported the override in the .profile file in according with manjaro-base-skel right ?
philm commented 2017-03-21 18:08:09 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: udeved
Yes, but you probably have to put it somewhere else, eg ~.bashrc.
*Created by: udeved* Yes, but you probably have to put it somewhere else, eg ~.bashrc.
philm commented 2017-03-23 22:07:56 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
I have open a ticket here
https://sourceforge.net/p/qt5ct/tickets/35/
i try to add in .bashrc , .pam_environment and also in .xinitrc but nothing change .. if i want open the app ( i.e. qt5ct ) via control center of mate and also in gnome i have to add the override in /etc/environment :\ . Any issue if add this override only in my de s ?
*Created by: Ste74* I have open a ticket here https://sourceforge.net/p/qt5ct/tickets/35/ i try to add in .bashrc , .pam_environment and also in .xinitrc but nothing change .. if i want open the app ( i.e. qt5ct ) via control center of mate and also in gnome i have to add the override in /etc/environment :\ . Any issue if add this override only in my de s ?
philm commented 2017-03-24 18:20:20 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
After other test at the moment only Mate is affected so i put the overlay only for mate
github.com/manjaro/iso-profiles@cca311f88a i don't know why mate control center not recognize the variable ...
*Created by: Ste74* After other test at the moment only Mate is affected so i put the overlay only for mate https://github.com/manjaro/iso-profiles/commit/cca311f88a3967c37f174791b5b309b681b696bf i don't know why mate control center not recognize the variable ...
Sign in to join this conversation.
No milestone
No project
No assignees
1 participant
Notifications
Due date
The due date is invalid or out of range. Please use the format "yyyy-mm-dd".
No due date set.
Dependencies
No dependencies set.
Reference
profiles/manjaro-gnome-settings#1
No description provided.
