Dash-to-dock keyboard shortcuts no longer work #21
Closed
opened 2022-06-08 12:35:07 +00:00 by ghost · 1 comment
ghost commented 2022-06-08 12:35:07 +00:00 (Migrated from gitlab2.manjaro.org)
Hello,
When using the "dash-to-dock" extension, the Super+(0-9) keys allow for quick access to pinned applications thanks to an extension configuration.
In manjaro-gnome-settings version 20220526-1, the shortcuts work the intended way, launching the applications.
After updating to version 20220606-1, the Super+(0-9) keys no longer do anything. Toggling the extension setting allowing for this behaviour does not seem to affect anything. Reverting back to the previous version solves the problem.
Using a french "AZERTY" keyboard, on Manjaro rolling with GNOME 42.1, and using Wayland.
Could you take a look at this issue please?
Hello, When using the "dash-to-dock" extension, the `Super+(0-9)` keys allow for quick access to pinned applications thanks to an extension configuration. In `manjaro-gnome-settings` version `20220526-1`, the shortcuts work the intended way, launching the applications. After updating to version `20220606-1`, the `Super+(0-9)` keys no longer do anything. Toggling the extension setting allowing for this behaviour does not seem to affect anything. Reverting back to the previous version solves the problem. Using a french "AZERTY" keyboard, on Manjaro rolling with GNOME 42.1, and using Wayland. Could you take a look at this issue please?
yochananmarqos1 commented 2022-06-08 18:05:59 +00:00 (Migrated from gitlab2.manjaro.org)
Dash to Dock's shortcuts conflict with our default settings as well as Pop Shell's settings. You are free to set your own custom shortcuts as you please.
yochananmarqos1 (Migrated from gitlab2.manjaro.org) closed this issue 2022-06-08 18:06:00 +00:00
Sign in to join this conversation.
No milestone
No project
No assignees
1 participant
Notifications
Due date
The due date is invalid or out of range. Please use the format "yyyy-mm-dd".
No due date set.
Dependencies
No dependencies set.
Reference
profiles/manjaro-gnome-settings#21
No description provided.
