Suggested desktop setup #8
Closed
opened 2017-07-19 16:33:57 +00:00 by philm · 1 comment
philm commented 2017-07-19 16:33:57 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: es20490446e
The desktop
With the purpose of enhancing ease of use, and usability when managing plenty of windows, I made the following desktop setup:
Which can be tested using this installer.
Motivation
In the beginning I made it for my own convenience and for my friends. But I thought that perhaps you will find some these concepts interesting, and borrow some of them as liked.
Probably I would be finally using KDE plasma instead as my recommended desktop environment. As it recovers more gracefully from crashes, has a more regular performance, it's applications are more portable across platforms, has less bugs, it's more versatile, and finally it doesn't remove features that truly makes life easier.
Even then I have all the intuition that many people using GNOME would find this setup very appealing, and much more easygoing than the default GNOME desktop.
Note that the purpose wasn't to make the interface minimalist, but rather that was a collateral result of fitting it to true usage.
Design principles
Lastly more important than the end result, I think it's knowing the ideas behind it.
*Created by: es20490446e* ## The desktop With the purpose of enhancing ease of use, and usability when managing plenty of windows, I made the following desktop setup: - [Empty desktop](https://i11.servimg.com/u/f11/16/19/87/90/screen10.jpg) - [File manager](https://i11.servimg.com/u/f11/16/19/87/90/screen10.png) - [Applications menu](https://i11.servimg.com/u/f11/16/19/87/90/screen12.jpg) - [Status bar menu](https://i11.servimg.com/u/f11/16/19/87/90/screen11.jpg) Which can be tested using [this installer](https://github.com/manjaro/manjaro-gnome-settings/files/1159706/Minimal.Manjaro.GNOME.interface.zip). ## Motivation In the beginning I made it for my own convenience and for my friends. But I thought that perhaps you will find some these concepts interesting, and borrow some of them as liked. Probably I would be finally using KDE plasma instead as my recommended desktop environment. As it recovers more gracefully from crashes, has a more regular performance, it's applications are more portable across platforms, has less bugs, it's more versatile, and finally it doesn't remove features that truly makes life easier. Even then I have all the intuition that many people using GNOME would find this setup very appealing, and much more easygoing than the default GNOME desktop. Note that the purpose wasn't to make the interface minimalist, but rather that was a collateral result of fitting it to true usage. ## Design principles Lastly more important than the end result, I think it's knowing the [ideas behind it](https://plus.google.com/+AlbertoSalviaNovella/posts/JsN2LwvyZJ8).
philm commented 2017-07-19 19:56:33 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Thank you for your suggestions! My vision of Manjaro Gnome is that it should be different enough from other dostros‘ Gnome. I don‘t see enough difference in the settings you suggested. I will keep in mind what you suggested and see what I might want to implement. Thank you!
*Created by: Ste74* Thank you for your suggestions! My vision of Manjaro Gnome is that it should be different enough from other dostros‘ Gnome. I don‘t see enough difference in the settings you suggested. I will keep in mind what you suggested and see what I might want to implement. Thank you!
Sign in to join this conversation.
No milestone
No project
No assignees
1 participant
Notifications
Due date
The due date is invalid or out of range. Please use the format "yyyy-mm-dd".
No due date set.
Dependencies
No dependencies set.
Reference
profiles/manjaro-gnome-settings#8
No description provided.
