Nautilus configuration #9
Closed
opened 2017-08-14 21:31:30 +00:00 by philm · 11 comments
philm commented 2017-08-14 21:31:30 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Chrysostomus
There have been requests of
  • sort folders before files
  • typeahead support
  • files in ~/Templates/ for empty text file and shellscript.sh
*Created by: Chrysostomus* There have been requests of - sort folders before files - typeahead support - files in ~/Templates/ for empty text file and shellscript.sh
philm commented 2017-08-15 18:58:01 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Hi matty.. for me is holidy time, i come back at my home and at my pc only after the 21/8... anyway the first issue is simple to solve: is a key in gsettings to modify.
The second i not understand fine what you mean and for the third issue not work the actual empty file wirkaround for gnome and deepin ? nautlis-empty-file pkg?
Stefano :)
*Created by: Ste74* Hi matty.. for me is holidy time, i come back at my home and at my pc only after the 21/8... anyway the first issue is simple to solve: is a key in gsettings to modify. The second i not understand fine what you mean and for the third issue not work the actual empty file wirkaround for gnome and deepin ? nautlis-empty-file pkg? Stefano :)
philm commented 2017-08-15 19:22:59 +00:00 (Migrated from gitlab2.manjaro.org)
  1. as you said
  2. would be aur package nautilus-typeahead. It re-enables typeahead, meaning that when you start typing in nautilus, you don't automatically do recursive file search, but instead select a file in the current folder that matches to what you typed. Normal file search is accessed with ctrl+f. Install nautilus-typeahead and see what I mean.
  3. I thought this could be done with just adding empty /etc/skel/Templates/empty\ file. Do you mean that this might not work because of location differences?
*Created by: Chrysostomus* 1) as you said 2) would be aur package nautilus-typeahead. It re-enables typeahead, meaning that when you start typing in nautilus, you don't automatically do recursive file search, but instead select a file in the current folder that matches to what you typed. Normal file search is accessed with ctrl+f. Install nautilus-typeahead and see what I mean. 3) I thought this could be done with just adding empty `/etc/skel/Templates/empty\ file`. Do you mean that this might not work because of location differences?
philm commented 2017-08-16 18:06:50 +00:00 (Migrated from gitlab2.manjaro.org)
I uploaded the nautilus-typeahead to unstable repos in case you are interested in testing it once you have the time.
*Created by: Chrysostomus* I uploaded the nautilus-typeahead to unstable repos in case you are interested in testing it once you have the time.
philm commented 2017-08-16 20:21:19 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Yep, sure i want test :) .. for the empty file yes @oberon2007 create this pkg as a workaround for the locale translations.. templates is not equal when user choice the localization ... with the same prunciple we can create another pkg to do the bash template file or modify the old for do togheter the template...
*Created by: Ste74* Yep, sure i want test :) .. for the empty file yes @oberon2007 create this pkg as a workaround for the locale translations.. templates is not equal when user choice the localization ... with the same prunciple we can create another pkg to do the bash template file or modify the old for do togheter the template...
philm commented 2017-08-22 16:09:10 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
@Chrysostomus for shellscript.sh you mean a template with this content at first line ? :
#!/bin/bash
Edit : add support in Nautilus for sorting directories before files github.com/manjaro/manjaro-gnome-settings@84955477fd
*Created by: Ste74* @Chrysostomus for shellscript.sh you mean a template with this content at first line ? : #!/bin/bash Edit : add support in Nautilus for sorting directories before files https://github.com/manjaro/manjaro-gnome-settings/commit/84955477fd8cfc13052d1313a10b9b5fbd359321
philm commented 2017-08-22 17:20:50 +00:00 (Migrated from gitlab2.manjaro.org)
Yes
*Created by: Chrysostomus* Yes
philm commented 2017-08-22 21:16:26 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Well , two of three correction are in unstable , sort directory before files done and also a Empty Bash file come with my last commit : nautilus-empty-file pkg create two template now ..
for nautilius-typehead not sure if we have to maintain because i read also canonical drop the patch because this patch have to be rebuild any time a new nautilus release is out ( ubuntu 17.10 drop it ) :\
*Created by: Ste74* Well , two of three correction are in unstable , sort directory before files done and also a Empty Bash file come with my last commit : nautilus-empty-file pkg create two template now .. for nautilius-typehead not sure if we have to maintain because i read also canonical drop the patch because this patch have to be rebuild any time a new nautilus release is out ( ubuntu 17.10 drop it ) :\
philm commented 2017-08-22 21:26:28 +00:00 (Migrated from gitlab2.manjaro.org)
Okay. We don't have the resources to maintain without upstream source. So probably no then.
*Created by: Chrysostomus* Okay. We don't have the resources to maintain without upstream source. So probably no then.
philm commented 2017-10-31 16:42:56 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
@Chrysostomus since we have gtk3-classic pkgs we should close this . Re-open if needed
*Created by: Ste74* @Chrysostomus since we have gtk3-classic pkgs we should close this . Re-open if needed
philm commented 2017-10-31 16:55:12 +00:00 (Migrated from gitlab2.manjaro.org)
I think gtk3-classic solves it only for the file chooser dialog and not nautilus. But since we agreed we cannot maintain it, the issue should be closed anyway.
*Created by: Chrysostomus* I think gtk3-classic solves it only for the file chooser dialog and not nautilus. But since we agreed we cannot maintain it, the issue should be closed anyway.
philm commented 2017-10-31 17:01:13 +00:00 (Migrated from gitlab2.manjaro.org)
Created by: Ste74
Honestly not looked into the gtk3-classic :p ....
*Created by: Ste74* Honestly not looked into the gtk3-classic :p ....
Sign in to join this conversation.
No milestone
No project
No assignees
1 participant
Notifications
Due date
The due date is invalid or out of range. Please use the format "yyyy-mm-dd".
No due date set.
Dependencies
No dependencies set.
Reference
profiles/manjaro-gnome-settings#9
No description provided.
